Yore spit hole matching is just fine tonk!!!
The key here is no overhang in the hole matchup anywhere. Either in the oil going in, or the oil going out, or oil going up and oil coming down by gravity. Unimpeded flow. That's the ticket!
No turbulance/restriction, no offset that allows gunk to gather over time, etc. I seriously doubt that your engine will ever develop any of the lubrication-related syndromes we've been kicking around here for the last several weeks simply because the oil will be changed onna regular basis and you will maintain the motor as it should be! Great pics of the process involving difficult access!
There is nothing "wrong" with the oem lubrication design if the engine is simply maintained. Only the Scout II had any lubrication-related "fault" and that was created by the funkee double-hump oil pan sitch to allow 4x4 steering axle clearance, none of the other applications of the sv engine had that type of concern.
And the top end oiling issue would not exist either for engines which had regular service.
Last Tuesday, I pulled apart approximately twenty rocker assemblies and separated the components as future candidates for reconditioning. This batch included several nine stand assemblies that were set up oem with boat rockers, some were set up as five stand assemblies, and a few were a mix of both types of rockers! Some were so badly gunked and sludged, I had to give up and bring 'em home to soak in tyme before they will come apart.
And yes, both the welded rocker shafts and the boat rockers shafts each showed the same type of extreme wear pattern, that is caused by lack of lubrication due to restricted oiling passages and paths, not by design issue.
More info on that sitch will be posted in this thread:
