PAscout800
Hey everyone.
Got the engine running and carb rebuilt, now on to the brakes.
I bled the master cylinder (still a little soft but had resistance). Reinstalled the brake lines. Started with passenger rear. No bleeding. Took out bleeder screw, cleaned the passage well, still no bleeding. Same with driver rear and front two.
At what point do I just all new hard lines and rubber hoses? After I try to vacuum bleed? Replace brake cylinder first? Try to chase it to maybe a clogged portion of the hose?
