74Orange
74 pickup, 345 v8, 2210, points distributor.
I recently power-timed The 74 pickup and noticed afterwards that my engine is running cooler. The norm before power timing was my temperature needle being about 1/4 of the way between the "c" on the left and the "h" on the right, after engine was fully heated up and cruising.
Now, after power timing, the needle is much closer to the "c", almost touching the line, at full heat.
Does that sound right, for a timing adjustment to make a difference in engine temperature? I should say that I only retarded the timing during the change (at least I think I was retarding; I turned it a few tiny budges clockwise).
Also, if it matters, I recently had my radiator tank repaired and rodded. Thing is, when I got it back in the truck about a month ago, it went right back to that temperature that it ran at normally (about a 1/4 of the way on the gauge). It was only when I power timed it yesterday that the temperature drastically decreased.
