pineneedle
Michael,
several months ago we corresponded about my distributor. To refresh your memory, it is a prestolite electronic off a 1978 304. It has two wires that lead to some electronic stuff under the main plate. At the time we last talked, you said to take it apart and to assess the wear. Well, I got sidetracked into axles and other stuff, but I am now back to the distributor. It has .042 end play. The bushings seem very tight, the bottom having no runout at all. The top has about .003 measured at the end of the shaft. What do you think?
There is an eight bladed thingy on the top end of the shaft. I presume that this is an electronic trigger of some sort. Since I am going to go with a pertronix igniter, I presume that I take this piece off. Is that correct? Is it just a press on fit to be pulled off, or is there some special mo-jo necessary?
As always, thanks for your help.
Pineneedle
Pineneedle
