Hey folks, I have a question.
What is the most common distributor used in Scout's? I have a 1977 SSII that came wiith a Holley and gold box. I switched to a 1979 prestolite and installed a pertronix unit. Runs fine. However, I want to put together a "spare" distributor for off roading. In the event the pertronix goes out, I have the spare. I have heard that some guys use the old "points" distributor because they are a "no-brainer". Another question, what distributor is the most used with a pertronix unit, an original points distributor or an electronic distributor?
Last question, knowing that the pertronix burns out with the key in the "on position" without the engine running, is there another wiring solution that would get around this issue? I heard that if the positive wire of the pertronix is wired into the oil sending unit, it would work.
Any help would be appreciated.
, you cannot get the key to the off / lock position and get it out of the ignition switch.
