harrywt
Hi guys,
I've got this '72 sii that I bought in the fall and have been slowly correcting the po issues.
The biggest headache (thrill source on the road) is the sophomorish SOA conversion. The two pics show the "perches" and shackles, also note the drag link angle. I'm sure the positive caster is painfully evident.
Ok, so I have replaced the shackles with IHPA 3/8" thick shackles front and rear. John tabor supplied me with these custom made greasable 5/8" bolts to replace the supplied bolts. You enlarge the holes in the shackles and eliminate the center metal bushing from the poly spring bushings. All the spring bushings are now poly.
The steering box was loose on the frame so I tightened it. I also snugged up the lash and of course I found out why it was so loose to begin with, need a new box.
Oh, and the alignment was way out so now I have a 1/8" toe in.
Now I have much tighter steering but it still has a mind of its own. I measured the caster, positive 15 degrees!! I knew that this was my biggest problem but I was still surprised.
Today I made "official" measurements on a truck scale at work so I know that I was on a level surface. I put the results in the attached pdf.
I am going to have the yokes twisted. Since I am going to replace the excuses for perches I thought I might double check if the differential tilt is satisfactory.
As you can see in the drawing, there is a ten degree difference between the diff and the driveshaft. This angle will get smaller as the springs depress and larger when they relax.
My first guess would be to make this angle zero so that the angle then goes plus and minus as you go over bumps. But maybe the shift would hit something?
And what caster should I aim for? I'm thinking 6 degrees negative so if I left the perches as they are I would have the shop twist the yokes 21 degrees. Of course, if I decide to change the diff angle this twist would increase.
Best regards,
harry
Best regards,
harry
