Rentalman
Active member
Hello IH Community. I think my Pertonix III coil is bad? Since the rebuild I have driven it 250 miles. I'm trying to figure out if I damaged the coil. The last time I took the Scout out for a drive was 2-weeks ago to follow up on the repair of my temp guage. It drove great and the temp guage now works. Since then I added a USB dual port-12 volt charger. I grabbed the 12v power off the accessory location on the ignition switch and added a 5 amp inline fuse. For the ground wire I grounded it to the bolt on the fire wall that the heater duct attaches to. The 12v USB charger would only get power in the ignition switch run position and not the accesory position. Ever since I got the scout running I have needed to adjust ignition switch on the steering column. It would start and run but the rod adjustment was off a little. To shut the engine off I would have to actuate the steering lock lever. I loosened the two screws that hold the ignition switch to the column and moved it about 3/16" of adjustment. Prior I rewired the scout with a Quick Wire Kit. So I had the option to turn the power off to the coil when I would turn the key to the start position and test all the detent spots on the ignition switch; start, run, off, lock & accessory. I cant rember if I killed the power immediately before testing the ignition switch or sometime after. It is possible I may have had some cranking time on it before I killed the coil power?
So prior to me adding the 12v USB port and adjusting the igniton switch the Scout would start and run. Or is this failure a coincidence?
I called tech support at Pertronix for advise. From the coil OHM readings I gave him he belives the coil is shot. 1.117 OHM for primary resistance and 7.90 for secondary resistance. Those values may be off because my multimeter I belive was not woring correctly. He told me those coils rarley fail. The three deaths are over cranking the engine to start, wrong coil for electronic ignition and a postive voltage leak in the frame of the vehicle. He said for me to check for 0 OHM's at the distributor plate near the Pertonix Igniter III.
I bought a new multimeter today. Below are my test results.
Primary Resistance measured at 200 OHM = 0.5
Secondary Resistance measured at 20k OHM = 6.80
I have 12 volts at coil with key in run position
1 have 12.77 volts at battery, not running
I checked OHM's at distributor backing plate = 0.3 OHM
I checked all grounds and various other metal points = 0.2 OHM
I checked various grounds and bare metal with negative lead from MM and positvie lead at battery positve = all resulted with 12.77 volts
I checked spark at spark plug # 2 with a Lisle Spark Tester = yellow orange spark
My findings are the sprake was week. I was unable to test from coil because the spark tester would not fit into the coil.
Any advise will be much appreciated. Have a Great Week!
