Jeff suggested I post some pictures of my transfer case gears to see if these need to be replaced prior to ordering a rebuild kit. This a single stick Dana 20 from a 1970 800a w/304 and 4 speed manual.
The rear sliding is the worst with about 4-5 teeth looking as in the pictures. The idler is next with all the teeth looking like those shown in the pictures. The front sliding is the best looking of the three.
The reason for the rebuild was the transfer case coming out of low range into neutral under a load. The shift forks, shift bars, and all bearings look good. Also the front bearing retainer (picture 11) has a broken lip. Should this be replaced?
Please let me know if you think these parts should be replaced.
Thank you.
Tom
Thank you.
Tom
