D300 speedo drive
SLEMMON
I have a d300 on my Scout II and I am missing the guts where the speedo cable attaches. Where can I find these items?
Thanks steve
Okay, I tore it apart and found a piece of the speedo cable broke off in the speedo gear tube. Got that out and now I have another question, do I need to use this part or not? It was attached to the d20 that was taken out.
That part is used to calibrate the speedometer for what ever gear ratio and tires you are running. Put in in and see how close things are.
Okay, I thought that might be the case. But since im running 33's and 3:73's. It will be off anyway. Just wondering how far off it will be with out it. The Scout isnt running right now so no way to test it with or without.
Steve
With it in you can see how far it is off and then get the correct ratio gears to correct it.
