doubleR
I got my engine removed and ready to install front and rear crank seals. When I put the front seal in, should I put a lil sealant on it or oil, or just put it in dry? I decided to to change the oil pan gasket as well instead of using the lil cork gasket that came with the timing cover set. The boys in brown should be bringing the rear seal and other parts from you tomorrow. What about the rear seal, dry,a lil oil or sealant?
This is on a 266.
This is on a 266.
