CPT Gold tie rod and drag link install
FiremanMart
Hello, is there any way someone could please list the steps in order of replacing stock components with the new gold series parts. I just don’t want to miss a step or do some thing out of order that will cause more work in the end. I have a stock 69 800A. Or point me in the direction of a previous thread of the same.
1. Remove old tierod, draglink and pitman arm.
2. Unbolt front axle and install shims to front leafsprings. This step can be skipped if you already have shims installed.
3. Install new tierod, draglink and pitman arm. Do not mate draglink to tierod quite yet.
4. Set toe adjustment. Now you can mate the draglink to the tierod.
5. Center wheel by adjusting draglink.
