jauringer
Unfortunately more questions. Robert, you've been such a big help with the couple I've already asked, I'm starting to feel like I need to run more past you
304 contoured piston, .060 over, new kb pistons (non hypereutectic), isky split duration cam, 8.8cr
one is ring gap for sealed power, premium molly rings. Machinist recommended that I add .010" to the top ring which kind of goes along with some of the info I've read on kb's site. Just haven't found much on the second compression and oil control ring. Should I adjust them to the high side of spec as well? What would you recommend?
Second are lifter bore grooves? Hocus pocus? Seems like a pretty simple way to increase flow to the lifter/cam lobe contact area. What do you think about'em?
Thanks a bunch,
jason
Thanks a bunch,
jason
