stu simpson
I am trying to help out a couple of folks with throwout (to) issues. Both are experiencing problems that make it seem that their to assemblies are too short.
What is the correct length of the to assembly for a v8 Scout II with a t19? Does the type of clutch plate matter?
What is the correct to assemly loa for a sii with a 196ic and a t15 3 speed? Again, does the clutch plate matter?
I have recently been made aware that the v8 t90 takes the same bearing but a 2 13/16" sleeve. I have a 196ic/t19 setup on the floor of my shop, it worked when removed and uses a 3 3/8" long assembly.
All of the extra assemblies I have for sv applications are 3 3/8" long, which is not meant to imply that they themselves were right for the specific application. The bearing on these examples is pressed down to the shoulder of the machined surface/casting interface, not pressed onto the tip, which makes a 4" long assembly overall. Also, it seems that the correct finger heitght for all plates is 2.125 to 2.25", so the only variable should be the sleeve or the to fork on the cross-shaft in the bell. In these two above cases, the owners have determined that the bells and forks are not the issues.
Anybody?
Anybody?
