mrscullini
'79 scoutII, 345 with prestolite distributor with recent pertronix upgrade.
On the battery, I installed quick release terminals, the vehicle sits a lot so I remove the terminals so the batter doesn't drain. It has worked great. Downside is, when I do connect the battery terminals I don't always get a good connection. So when I try to start, I'll get a small arc on the pos terminal. I'll pull the terminal off, clean the carbon with scotch brite and reconnect. This sometimes happens multiple times before it finally starts. I know, the quick release terminals are junk.
Anyway, yesterday, this happened and now no start. I've got fuel, the thing cranks and cranks. Could that momentary arc on the battery cook a pertronix module? Is there a simple resistance test I can do on the module?
