brycewetton77
I have a 77 Scout with a manual trans with Dana a Dana 44 rear axle that has a bad differential (bearing is going out causing the pinion to bind up while driving) I was wandering if there was any way that I could use an axle from a 79 Scout with an automatic transmission..... I know the axles are the same size I just dont know if the gears are the same on both differentials.... How would I figure this out?
