So I have installed the flywheel, clutch and transmission! Thanks to IHPA for trying to get info from the clutch rebuilder!!
I was not able to get a definitive answer to the dimension for setting the clutch finger screws. If you have followed this thread and the "t19 install in korea" thread you May have noticed that I have been building up a picture of what the adjustment accomplishes.
Of course the most important thing is to have the throwout bearing contact evenly every time you press on the clutch pedal. That's the easy part.
At the end of the day it is a matter of making sure that you can adjust your clutch pedal over the life of the friction plate. We all know the rod that goes from up by the steering rod and down through the floor to the relay lever. It is threaded on either end but with opposite handedness, same as a tie rod, same as the screen door save you buy at the home depot.
When your friction plate is new, the rod should be adjusted to its shortest length and as the friction plate wears you lengthen it gradually to have the clutch engagement point in the pedal travel stay in the same place.
Now there are three levers on the way to the throwout bearing, 1) the clutch pedal, 2) the relay arm and 3) the throwout arm in the bell housing. We need all of them because the springs in the clutch are badass strong. I couldn't budge one clutch finger while placing all 240lbs of harry against it.
With three different levers it is difficult to calculate how much swing of the clutch pedal translates to movement of the throwout bearing. So we have a table in a shop manual to look up how far the clutch fingers should be from the flywheel face when the clutch is ready to install. In fact 99% of us let the clutch rebuilder do it for us.
What I did was take the old adjuster bolt that was assembled to the highest clutch finger and measured the distance from the bottom of the jam nut to the top of the head. I then matched the new adjusting bolt to this dimension. I installed this new bolt and used it as a fiducial. I then made sure that all of the bolt heads were coplanar with a digital level and an old bearing race. It was a bit tricky, I should have done it on an assembly table. I tried to level the flywheel but I found it easier to get the flywheel very steady on the table and then match the bolts to the flywheel. If the flywheel was at 0.9degrees then I made that bolt axis 0.9degrees. This definitely introduces some error but I decided to accept it.
So now some pics and I have to get back to some "honey do" stuff, more later.
