Yepp, I have to check again with the push-rods from the 345. I don't have a consistent set for the 392, it was already torn down and in more or less incomplete piles when I got it.
Could try swapping over the rocker setup as well. Not sure what kind of hg is running in that engine, it might be a steel shim. The 392s have always been running composite hg at ~0.04" afaik.
If I'm able to run the parts I already have in the 345, nothing is better than that :-d
