Robert Kenney
Super Moderator
I see we are a little out of sync on our posts.
after the new rods are weighed small end and big end with the bearing the piston and one ring set. Are also weighed and all parts are matched to the lightest one small end to small end etc with exception of the rings and bearings.
If you are replacing parts the old ones are no longer relevant.
Yes if you change rods to the newer type they May be very close as the parts are interchangeable by IH parts books but checking can't hurt.
One example is tim potters engine. It was machined in an attempt to lighten the reciprocating and rotating parts so the rods were modified so they are no longer IH spec weights. We are changing rods so all needs to be checked. Bad thing here is that the rod weight change made it necessary to lighten the crank excessively so it May be to light to balance with the new rods without adding mallory (carbide based heavy balance material) to the counter weights. That is when balancing can get pricey. You are not likely in that situation but I thought I would add the info.
and ignore all of the other stuff although some is relevant to much of a good thing is still to much of a good thing.
