cam selection
I have decided that I'm not going to do any decking, but rather just roll with it. I think the compression will be good enough for now.
Don,
in this case you should make sure the intake lobe center line is @ 104-108 installed. I think the cam you purchased is 110 but May be ground with 4 degrees advance built( intake lobe cl of 104) in it as this is comps mo. The cam card should say.
The advancing will help preserve cylinder pressure that you will need.
Robert
