grendel_cave
I need help selecting the correct cam for my 196. Jeff tells me that I can get one custom ground, go stock, or grab one off the shelf that already has a custom grind. The 196 is going in a '63 Scout 80. The truck will see mainly highway miles, with some mild off roading. The idea is to someday driving it coast to coast. I am raising the compression of the engine to 9.5, no more than 10. I also have plans to balance the crank, do some slight decking/milling of the head and block. I don't want a really high performance grind, just one that is geared toward slightly higher performance. Better fuel efficiency would be a definite plus. Any ideas as to what kind of grind I'm going to go with?
