I have a pretty bad leak from the brake proportioning valve on my 1978 Scout. Every time I apply the brake pedal brake fluid pours out of a small hole on the valve. Please see the attached image. I apologize that you will have to zoom in to see the text that I added. Does anyone know how or why I would be leaking brake fluid out of the small hole on the valve? Is there a set screw or purge valve that has malfunctioned? Also, there are two other sensor hookups that are on the valve that I do not quite know what they are used for or what they do. Any help would be great. I have found a replacement valve online for about $150. Can anyone recommend a place to purchase a new valve for a good price? It is obvious that I need to replace it, but it would be great to know how or why it failed. Thanks for your help.
Thanks,
angela
(408) 393-9500
[/font]
Thanks,
angela
(408) 393-9500
[/font]
