JERM
I have lost my brake lights. My rig was not running for a while and I changed a lot of the wiring. I have tested and replaced the brake light switch, cleaned the ground on the lights, and replaced all bad wiring I can find. My taillights are working but no brake lights. I replaced the steering column with one from a Chevy, and I haven't wired it for turn signals yet.
If I wanted to re-wire only the brake lights would I run 12v to one side of the brake light switch, then connect the wires going to the brake lights to the other side of the switch? If the grounds on the lights were bad, I don't think the tail lights would be working either.
1962 Scout 80
1962 Scout 80
