Hey everyone, back to dealing with my blowby issues.
Ok been running my Scout for a while mainly weekends, had just put a supposed factory rebuilt 196, in the '66 Scout 800, manual trans, Holley/weber 5200, petronics ignition stock type.
The truck runs great especially after getting the carb dialed in and jetted.
However I noticed some tim ago that pressure is coming out of the oil fill cap in the valve cover. Checked and double checked all pcv routing, and anything else I could thnk of, I have a little experience with IH engines, however I am stumped, I can't get this to stop. When you put your hand over as is near to the hole when open you feel pulses over air coming out as if a valve is open. Took valve cover off check everything there, adjusted the "retorqued", checked valve open close. Compression is the same in all 4 cylinders. No smoke, no excessive fuel burning, plugs look good, nothing seem out of order.
Where is this coming from?
Any help would be great!
