Best engine upgrade
romaniii
I have a 68 Scout 800 with a 266 v8 4 speed and want to put a bigger IH motor in it what is best to swap in 345 or a 392 and will the bolt up. I have a line on both motors not sure witch to choose the 392 comes with ps something I could use badly
For an engine swap such as this where you have both engines available, I'd certainly go with the 392.
All sv engines will interchange though there are differences in motor mount bosses (and tapped holes in the mount locations. That depends upon what platform the engine was originally installed in.
The 345/392 is about 1/2" taller at the exhaust port than a 266/304, so the header pipes May end up being short.
Big issue is what transmission setup and therefore whether it uses a flywheel or a flex plate. You can't simply swap the rear sections of the engines around, the entire lower unit segments of these engines are balanced at the point of assembly using parts that are unique to each engine.
If you are going to have to swap stuff around, the flywheel or flex plate will need to be "neutral balanced" by a machine shop.
Easy answer. Forget about it. Much easier to find an 800 or sii that was originally equipped with a v8 as your engine swap platform. Not that it can't and hasn't been done in an 80. Its a big job that often resembles a boogered-up abortion unless you really know what the heck you're doing fabrication-wise.
