jaskispyder
1210 pickup (1973)
history: thermostat failed closed. Cooling system is not too bad... No real scale but I flushed it and had issues with boilover without thermostat and that was unusual with this truck. This made me buy the "exhaust gas in coolant" tester. The results are negative... No color change. So I performed a coolant system pressure test. I pumped up to 8lbs and left it all day. No loss of pressure, to speak of. So, I tried cranking over the engine and it was hydrolocked in cylinder 3. I pulled a plug and it was wet. I turned over the engine and coolant came out that cylinder. Sigh.
So. I am guessing the headgasket is bad, or a cracked head. Does this sound about right? Any chance it could be related to the intake gasket? Is there a way to check the intake? I do get a little white exhaust on the driver's side of the vehicle, and sometimes it is hard to see.
No water in oil, no oil in coolant.
Any tips of looking for intake leaks? Any tips on removing the heads? Do I have to pull the distributor and exhaust manifolds? I have a ihc service manual. I have changed headgaskets on a fuel injected car, so I am not concerned, but I am just looking for some short cuts.
Thanks!
Thanks!
