Mark Pietz
I don't know if I'm on the right thread, or should be over in basic mechanical!
Now I'm really bent out of shape. I got to get my 1980 w/196 running well enough to get it into the garage so I can begin a real makeover!
History: pulled from a field; had been setting for x years. Who knows. Has the prestolite dist. And 1940 carb. I've gone through that carb about six times now in frustration. It's getting the accel pump squirt. This thing backfires through the carb when goosing it, idles fine, though. After it backfires, the engine slows down and idles rough, then eventually recovers, mostly. I've searched the threads about this and cannot rule out a sticking valve, but now just got done running it at idle with the valvecover off. All pushrods spinning and oil filling up the boats. Didn't notice any broken springs.
I replaced the dist. Cap. Timing is right, dist. Works (does advance when I can get it running faster), vac. Can works. I'm going to put new ignition wires on.
Next move?
Next move?
