brained
So this is going to be a slow build (working within spouse approved budget) of a trail/expedition style rig. Think of heading up into the trees for a couple weeks at a time on old abandoned logging roads or running the obdr comfortably.
These were originally posted on the bulletin so this one post covers about a years worth of other misc posts that I'm just now getting to.
Definitely going with a cargo rack on top. I'd like to tie it to an internal cage so the rack can remain even if the top is off. Not really heavy duty since I'm sprung over and don't want to get my cog to high by loading spare tires, water, etc up there.
Pics as it is now (spring 2009):
Here's the status as of this spring:
new brake pads, rebuilt slave cylinders, new front u-joints, new cap/rotor/plug wires, couple new brake lines, new tires (30x9.5 for now). One new electric wiper, led tail lights, cleaned up the speedometer with led backlighting/indicator lights (being able to see the turn signal indicator during the day is really nice!). Somebody already put in an alternator - I'm getting the pulley properly shimmed up. New electric fan. Po put in a rear d44 - 4.27's.
And here's the Scout getting outflexed by a Jeep on coils. We'll be doing something about that.
This to go along with it when the time comes but I'm working on turning this:
Into this:
Bulkhead cut out. Left a 3/4 lip, folded over and welded. In retrospect I'd have cut it closer to flush and then welded and ground it down. The 3/4 lip along the floor I think I will keep up though - keeps the 64oz cokes from flooding under the front seats.
New seat belts in too, hopefully it'll keep my son from bonking his nose on every water bar (maybe a few more serious things too).
Now to do something about the latex paint/carpet glue rust preventive coating the bed.
All better now. Put some hard plastic tubing over the lines and clamped them to the axle. No metal to metal contact, no vibration, no wiggling. This is before a cleaning with simple green to get the brake fluid off.
Into this:
got some nasty brake lines:
