Craig
Active member
Cut and paste from transmission thread.
I pickup 3 gals of this oil from Jeff.
I was skeered to mix this with other atf. Are you running this in your camey?
I see it compatible. I guess you need a machine to replace all the atf
I'd just like to add the fact that the swepco 714-20 atf is a great product to use in those trannies..... In fact you can use it as a replacement for all dexron, most mercon, and all chrysler specifications including the atf+4.
It provides smoother, yet more positive shifting to help reduce heat build up and has a higher additive package than anything else on the market. Transmissions typically run cooler, even without add - on transmission coolers.
I've supplied customers for practically any type of application, including from toyota to cat haul trucks, as well as drag car racing.
Jeff also stocks this item for his customers.
Dick
