Hello all. It's been a while since I've been on here but we just picked up a 2nd Scout II (1973 345/auto).
When it was cranked up for me to test drive it had a miss...I realized the #5 and 7 plugs wire were crossed...and then I realized all 8 wires were 180* off.
So I put them where I thought they "should" be and no start. (I guess I should have just made 5 and 7 right)
so at this point I figured the distributor was installed wrong. (the kid installed it 6 months ago and apparently hasn't driven it much since) no I preface this with I've never removed/installed a distributor.
So I pull #8 plug and have my wife crank it over and once I feel the big puff out of the plug hole I try to set the distributor in. Visually it appears to have lined up right where it needs to be. I then put the wires on according to the firing order with #8 starting out where the rotor was pointing to...still no start.
It has spark (heck I drove it)... It also has a jacobs 'omnispark' coil set up. I've never even seen one of these so I'm not sure if there's something I'm missing or if I've just plain got the dizzy in wrong...?
When it was running with the distributor in the wrong way it seemed to have good compression, was quiet, and did not backfire or act up at all other than the 5,7 wires being off so there was the miss... So I'm hoping it's just me being inexperienced of installing a distributor correctly.
I have friends who when available can probably come stab this thing in and have it running in no time but I'm impatient and also want to learn myself.
I'm really missing the Jeep I traded for the Scout so not being able to drive the ol' girl is killin me!!!
