Bill Bennett
While you seem to have covered the 'normal' places to check, you haven't said 'which' sparkplugs were installed and did you verify the plug gap? With a stock coil, try 32/1000. You have replaced the distributor but have you checked the 'dwell' of the points gap? Should read between 28 to 32 degrees. Was any 'lube' applied to the cam surface or 'rubbing block' of the points to cut down on wear? As for if it was stabbed correctly, it is - or the motor would not be running. There should be a number on the 'arm' of the vacuum advance unit. The number indicates the amount of additional advance supplied by the vacuum advance. As the dist is a reman unit, it will help to know the amount of 'mechanical advance' and the rate of advance. Then the vacuum advance will be added to the total.
Meanwhile, consider replacing the concenser in the distributor.
