IHCScout78
Hi,
considering your complete TBI system.
Does the o2 sensor require a bung to be welded in the exhaust? I have ceramic coated stan's shorty headers. Where do you recommend the sensor to be installed?
Do you have any vapor lock issues with the external fuel pump? I have had some bad experiences with rail mounted pumps on a previous efi conversion.
For a 345, which manifold(2bbl, square bare, spread bore) do you recommend?
If you had the aluminum manifold in stock, that would definitely be part of the project....
