int77345
Active member
i have an original 345 in my scout II. it started smoking last year, but only out of the right exhaust pipe, and only at idle, and only when the engine is around normal operating temperature. any engine speed above idle and the smoke stops. on a hot summer days last year the smoke would get pretty bad.
im thinking the valve stem seals are causing the smoke, or at least playing a large role in it. iv traced the problem to #6 cylinder. it is the only cylinder with a black oil filled spark plug, all other cylinders on good. putting a bore scope down #6 spark plug hole, and the piston is covered in oil, and carbon looking burnt oil .
questions---
1. what kind of valve seal is better ? the umbrella ones or the O ring type ?
2. installing the umbrella type does it push all the way down the valve stem ?
3. when removing the rocker arm rail assembly, does the engine need to be at TDC ? or does that matter ?
4. what kind of sealing do the rocker arm rail assembly bolts need ? none or some ? lock tite ? permetex ?
ill post up pictures as i go, it will be interesting to see what such a high mileage and old engine will look like under the valve covers.
questions---
