Have a 1980 Scout, 345, tg, prestolite w/o points. I hadn't driven it in 2 months, moved it 50 feet, then 2 days later it failed to start. After checking the obvious things, I realized there was intermittent voltage to the coil. After connecting 12volts direct to coil, still failed to start. Went ahead and replaced plugs, coil, cap, wires and rotor. No luck. Did all tests for operation of ignition, indicated trigger bad. Replaced trigger, same result. Took out distributor and had it checked at auto/electric shop, checked out fine, even with old trigger. Good gap on sensor. With a spark tester on the coil hi-tension lead and plug wires found out the wiring thru ignition switch would only create spark immediately after engaging starter and just at end of starter sequence (?) sparks fine with hot wire to coil. I have read all the ignition tech posts and can't find info that helps. Carb seems to be functioning, have checked tdc @ #8 cylinder, fiddled with timing, etc. Can anyone tell me what I'm missing!
