78 scout 2 door glass removal?
Got a 78 scott 2. Can't seem to get the drivers door glass out .removed the two clips holding it to the regulator and when I pull up it seems to get stuck in the top position. Is it getting hung up on the front vent window? Do I need to remove the front vent window and front rail to get the glass to slide out? Got a bad door latch and I have to remove the window so I can remove the rear rail and get to the latch assembly....
You again? Me again? This one is easy. On the top of the wing window frame there are two small phillips head screws that retain a rubber stopper plug. Remove the screws, slip the plug out and slide your glass up and out.
