My 76 Scout II, 345ci 4wd has a standard Dana 44 rear end. I bought and installed a rear disc brake conversion kit from ssbc. The id of the rotor is larger than the od of the axle hub and therefore the rotor is not properly centered on the axle. Can anyone tell me the correct rotor I should be using for the 76 axle. Ssbc is no help.
