tee jay
Adding some accessories in the cab of my 75 pickup. I found three factory wires under the drivers side dash that are switched accessories but the problem is they dont have a full 12 volts ,dim test light, and whatever you hook to them doesnt work right or not at all. Everything else in the cab has full voltage. Could this be a bad ignition switch or not the right wires? What would they be for if not? All ground wires have been either replaced or cleaned. Truck starts and runs so I guess the steering column is grounded?
