73 travelall body bushing info
Yellow73
Good evening,
I'm looking at replacing the body bushings on a 73 1110 4x4 Travelall, and searching for more pictures to study. My cts manual has a somewhat limited illustration, and was just wondering if anyone knew of a direction to point me in to find some better images. Thanks for your time.
What is this? Where does it go? Can't find pics, and can't locate under truck.
No. No destructions. The questionable bushing is according to rj, at outback, a body bumper. It goes on top of the frame rail about mid body...I'll hunt for it this evening after work. I had read that bp post, thanks. I'll revisit it in the uh...office.
You know that does look like it might go on top of the mount on the frame where the front of a pickup bed would go. There is a square pad there on the pickups, don't know about the ta's.
After close visual and finger inspection I cannot find where these are supposed to go on my Travelall. Could be just for pick ups. I'll keep looking, and try to document process. Thanks for the posts!
So I began to change them out tonight after work. Started in the front, worst spot. Loosened up the two under the cab closest to the firewall first. With some wood scraps and the long bar, I was able to pry and stack just enough to get the new bushing in. I kept an eye on the radiator fan and the shroud bottom. They got close, but it worked so far. Found a missing bottom bushing insulator on front and center. The new bump stops bolt through a hole in the spring hanger. The crimped nuts o.p. Supplied with the bump stops began to spin. I will use a regular nut with a lock washer.
Please bear with me while I learn the ins and out of posting here. I've been lurking long enough, thought I'd try to contribute for once. image.jpg
Trying to load another photo. There we go. Bushing fairly used.
