cruiserhead81
I bought this from Chad last fall and havn't had nearly enough time or money to work on it. So far I have swapped in a Chevy Dana 44 using 6" Chevy front leafs and on inch longer shackles. I am usinga 4" lift steering arm and a custom draglink with the Chevy and IH tie rod ends. I am will also be able to use the stock Chevy swaybar with very little work. For the rear I am working on removing the stock 3" block and going to add a 5" and that will level the truck. Future plans call for a Dana 60 and a cummins/nv4500 swap. I will update it as I go.
