nickc11211
I have a 79' Scout II with 36k original miles on it and the transmission is acting a little strange. When I first start it and let it warm up for a bit I go to shift into reverse and it is like nothing happens. I can rev it up and it will start to move, but very slowly. However if I shift through from park down to drive and then up to reverse and then up to park and repeat a couple of times then reverse is fine.
My other issue is that when the truck is cold the transmission seems to shift fine when driving, but after it warms up the shift from 2nd to 3rd there is a little rev up. Not sure what is going on but any information would be helpful. I think I would like to change the transmission fluid and put in the atf that swepco sells. How much do I use and is this recommended?
