Hello all. This is a very cool site. I just bought a 67 800 with a 152 4 cyl. 3 speed tran. It run but is missing out at lower speeds. A little about what has been done to the Scout. The person that had it before me put an aftermarket fuel pump in it which I will leave alone. I did have to wire a relay into it as well as wire it in. Is there a chance that it could provide too much pressure? It is a very small 12v pump.
What would I need to do a full tune-up?
I am going to replace the plugs and wires. Is there anything I need to do with points or a rotar cap or anything?
Basically, if you were going to do a full tune-up including an oil change what would you need to get?
Thanks,
cody
Thanks,
cody
