67 800 break trouble
This is showing not fitting
Interesting! Every Scout 80 or 800 that I have seen thus far has had a 7/16" bolt to hold the pedal to the pushrod. I'm guessing from what you just showed me is a 1/2" pin pressed into the pedal? If so I do not have anything available without making it.
what would cost to make something?
That part you found is exactly what is needed. I'll have to find out if my brake parts supplier stocks that otherwise you May need to pick that up from jegs to make your setup work. It would cost us more than $15 to make it.
So I got the new part from jeggs today and the the threads are smaller ahhahahhahahahahhahahah. The break job from hell. I should have just order another mc and rerun the break lines. I brought the eyelet to my welder and he going to take the two pieces and make I will post a pic when I get back.
