waveraider
I have an 1890 loadstar that I thought had a fuel delivery issue. Anytime I pull a hill or really put it under a load it will cough and sputter but not right away. Normally I can just downshift and make it through. Its only had about 1500 miles since I put a new fuel pump on but that was 4 years ago. The inline filter was awful so I changed that and flushed out the fuel tank. Seemed to do a bit better but ultimately not too much difference. I plugged the fuel line into a gauge and it was 5psi but then increased to about 8 over time after the motor was shut off. I assume it was the fuel line warming up the cold fuel- about 10 min. I never did wait long enough to see if it would die back down. I'm wondering if I should check under dist cap to see if timing advance is ok. Any help is appreciated
