I have a 392 non ic. It was in my school bus/rv conversion with a MT-40 allison automatic. Problem was it kept blowing out the coolant on long grades even though the engine temp did not rise. Two pistons melted exposing the top ring. So I removed the engine and put a good running 345 in it's place with a 5 speed manual.
I know the block is differant from the IC version, however I am wondering if I change the coolant pipes to go to the block instead of the head will that noticably improve the cooling so I do not get hot spots and melt more pistons, or is this engine just not suited to long haul highway use?
