if the donor engine was not in a Scout you will need to swap oil pans and get a different oil pump and pickup.
good point,
we dropped a 345 from a 79 Scout into our 74 loadstar, everything fit perfect, the only mods needed was the swappage of the electronic distributor.
We didnt change the oil pan and pump, everything works fine.
Good luck with your swap, its alot easier than one would think.
yep...a loadstar has plenty of space adjacent to the top of the front axle to be able to run any oil pan/pump set. Not so on a Scout II...thus the double hump oil pan and rear/extended pickup used in Scout II platform applications of the sv engine series.
An sii platform with oem suspension and front axle must use a double hump pan or a collision will occur when the front suspension compresses. An sii that has been converted to a spring-over front suspension has enough space to allow the use of the front sump pan as used on fullsize rigs as wells as medium duty and school bus platforms.
