Super Dave
I have a 1974 series 100 pu, sv345 and tf727,
Holley 1510 dist. W/ pertronix 1481 conversion.
Ps, pb
the motor runs 22xx rebuilt carb.
R6676a
448670-c91
0033
it starts right up on one pump and idles well. It has the the typical flat spot off idle and I no longer want to mess with it. Tired of dying in the middle of an intersection! I am ordering a 2300 with electric choke to replace to 2210.
As seen in the photographs, (sorry for all the links... I don't know how to get the photographs "inline" with the text...) the po "optimized" the 345. I would like to remove and toss the smog pump and complete the "optimization" to its fullest potential.
Question:
can I remove the smog plumbing from the exhaust manifolds and plug the holes with the proper threaded fittings, without mucking up something else? If I get everything back to being dependable, a set of stans headers will solve this issue.
Question:
what are the two vacuum port fittings on either side of the rear intake manifold used for and can I "optimize" them with a plugs as well?
Question:
what is the vacuum "module?" on the firewall used for? It has nothing connected but has tees for vacuum lines. Does a properly "optimized" motor need this?
Question:
there are several loose electrical connectors on the passenger side of the motor. Any input as to their use and relevance would be appreciated.
Question:
the egr canister is taking up space and has nothing connected to it. Can it be removed and plug the manifold?
Question:
I want to replace the stock air filter housing with an open element filter setup. Any recommendations against this? If so, why?
Any other recommendations, suggestions or "secret" applications to consider in the ongoing resistance movement of the smognazis would be greatly appreciated.
Sd
Ps, pb
R6676a
448670-c91
0033
Question:
Question:
Question:
Question:
Question:
Question:
Sd
