1974 international travelall 100
Abelal
So im working on a 74 international and finding the the rotors are such a pain im thinking about just swapping the axles out. And if im going to do that I might as well convert it to 4wd. Does anyone have any advice or know what parts I should be looking for or where I could fine. I know ill need front axle rear axle, t case, drive shaft. Anything else? Appreciate any assistance.
You will need the transfer case bracket and all three driveshafts. If you are planning to use a divorced np transfer case like a stock unit. Otherwise if you want to go with a scout ll transmission and transfer case.
