I got the pump cleaned out and put back together.
I cannot find a spec on how tight the pump bolts are supposed to be. When I tightened them to where I thought they should be the shaft would not freely spin.
I loosened and then re-tightened to 10 ft-lbs.
Is there a solid number I could use? I am checking the service manual pages 43-44 and page 64 for torque spec- other than the mounting bolts, I don't see anything.
Any other advice much appreciated. Without oil you got nuttin'.
Thanks!
~P.
Thanks!
~P.
