kingkonger708
I recently had a 196 swapped into my s80 to replace my 152 and have run into three problems. Would be interested in what I can do to troubleshoot, or any recommendations from the community.
1. On a limited test drive, I got a strange noise - a knocking sound that I can feel through the transmission by gripping the t-90's shifter. On a limited test drive this seemed to pop up after cornering (strange I know), and barely when accelerating. Sometimes it is smooth and there is no issue, other times it is significant. This one has me baffled!
Issue with the noise under power after the engine swap has gotten worse. Newly rebuilt tranmsission, transfercase, and drive shafts prior to the rebuilt and it shifted ran perfectly. After the engine swap, once it is in gear there is a loud chirping chattering sound in every gear. It goes away when I push the clutch in. It shifts smoothly into gear.
Help from the experts: what do you think it is, what should I do to fix/troubleshoot?
