1953 Internation R-130 Carb Gasket
Currently not near the car, but this is the last pic I had. I dont think it will help =|
Which gasket do you need? A bowl gasket, base gasket or ?? We need more information as well as a identification number off of the carburetor in order to properly assist you.
well I would like to replace all gaskets
Ok so it sounds like you want a carb rebuild kit. We need the information on the carburetor as we've asked before like the model and or list number. Without that, no one here will be able to help you.
Those numbers do not come up with anything when I run them thru my database. Please either try finding some other numbers or provide a lot more detailed pictures of this carburetor so that we can try and help you locate the parts you need.
Just going on the partial picture, it appears to be a zenith 28 or 228 series carburetor. If it is, there is a metal tag on the top of the float/fuel bowl with 2 numbers, and inner one and outter one. Then again the numbers signify a carter y or yf series. Please post some un-obstructed pictures of the sides and maybe one or two from the top. This would greatly help identifying the carb from long distance over the net.
