Robert Kenney
Super Moderator
Rob,
great pictures. I added text to one to indicate what I see and would do for the test in addition to blocking the pcv. I also assume the pcv you have is correct for the application and installed the right way around.
The intermittent bouncing vacuum reading to me indicates a sticky valve. Make sure the fuel is fresh and clean. Even the remnants of old fuel and varnish can exasturbate (abc?) the valve sticking issue. Even if you have verified that you have a good valve train oiling condition
